207 Pages«<1819202122>»
bjohnson
#191 Posted : Tuesday, November 4, 2008 4:06:24 PM(UTC)
bjohnson
I have a hotpoint HSS25IFMBWW. I have tried to troubleshoot the defrost heater but I cannot find the defrost timer on the diagram. Pretty sure it is not defrosting. The bottom half of the freezer cooling coil is frosty-snow like. the top half is a solid block of Ice. I tried to defrost it the best I could but I need to know if my refrigerator has the timer that I can try to adjust to test the heater. I am pretty sure the heater is not working but I need to figure out which part to replace. Also, the top damper on the refrigerator side has a faulty motor. The flap, if it opens, opens very slowly and not entirely. And the ice door solenoid also sticks halfway open often and looks very rusty but I cannot figure out how to get the Ice despenser apart to replace it. Thanks very much for any help.
#192 Posted : Tuesday, November 4, 2008 7:09:49 PM(UTC)
bjohnson,
There is no defrost timer in your refrigerator. It operates by the main control board (#801 on the break down diagram). You can find the complete troubleshooting instructions on page 3 in this thread. Lets do this first and then we'll proceed with another problems.
Here are the break down diagrams for the GE refrigerator Model HSS25IFMBWW
bjohnson
#193 Posted : Wednesday, November 5, 2008 4:02:31 PM(UTC)
bjohnson
I checked the resistance and it is at 22. Looks like a bad board. I checked the heater and thermostat and they are ok.
On an interesting note...In the process of moving the refrig back a griddle fell off the top and landed on the cord (thank goodness it was unplugged) causing an acute failure in electron transportation (cord was cut). Luckily that was an easy fix...I keep parts like that around just in case. Thanks for the help on troubleshooting the board.
#194 Posted : Wednesday, November 5, 2008 4:40:50 PM(UTC)
mposz
#195 Posted : Wednesday, November 5, 2008 9:49:36 PM(UTC)
mposz
Gene,
Replaced both and having no more problems. Thanks for all of your help.
Mike
#196 Posted : Wednesday, November 5, 2008 10:25:28 PM(UTC)
You are welcome, Mike. I'm glad you were able to fix it.
Ezel
#197 Posted : Monday, November 10, 2008 9:50:43 AM(UTC)
Ezel
after i wait 10 to 15 minutes should the defrost rod still be on
#198 Posted : Monday, November 10, 2008 11:54:54 AM(UTC)
Ezel,
It should stay "on" until the defrost thermostat would not open the circuit. Another word, it works by the temperature, not the time.
Eric Ettinger
#199 Posted : Thursday, November 13, 2008 6:38:56 PM(UTC)
Eric Ettinger
I turned the temp control all the way down. Fridge temp only dropped two degrees. Is it time for a new fridge? It is a 1986.
#200 Posted: : Thursday, November 13, 2008 6:53:50 PM(UTC)
How long it's been since you did it?
Guest (22)
