leeval
#1 Posted : Saturday, May 7, 2011 5:17:30 PM(UTC)
leeval
washer won't start and shows error code "dr" ...I reasd that it could be the door switch or the control board...is there a way to determine what part needs to be replaced?? or is it 50/50 ??
sidfink43
#2 Posted : Monday, May 9, 2011 11:23:15 AM(UTC)
sidfink43
Your machine has built in diagnostics and test to check the components. There should be a tech sheet inside the lower service panel that will tell you how to do the diagnosing and testing.
