Originally Posted by: richappy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) You probably have a burnt wire between the optics and ice maker, I have seen a few of these, generally impossible to fix. What I did, I presented the evidence to the customer and explained how it's virtually impossible to fix. i agree. customer accepts explanation
Check your schematic, the door switch may send voltage to the optics when the door is closed, might be blown open.AP31087668 This info is probably academic, the last one I worked on seems like lightning hit it as the top door switch was blown, together with the wiring, optics and ice maker!
Originally Posted by: richappy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Check your schematic, the door switch may send voltage to the optics when the door is closed, might be blown open.AP31087668 This info is probably academic, the last one I worked on seems like lightning hit it as the top door switch was blown, together with the wiring, optics and ice maker! the light switch works normally+optics are new
