donandlynn
#1 Posted : Saturday, May 7, 2011 7:32:41 AM(UTC)
donandlynn
My washer is leaking water from the bottom. I have a this problem before and the repair man said it was a filter that gets clog up and causes it to leak. I also called the samsung repair center and they said it would be found in the drain hose. I found a rubber black part not sure if that's it or not. I hope we can fix this without calling to have it repair. Thanks Lynn
sidfink43
#2 Posted : Sunday, May 8, 2011 2:56:07 PM(UTC)
sidfink43
Not a lot of experience with working on these models so about the best I can do is link you to a repair manual for a model that should be similar to yours.
https://secured.whirlpoo...sung_Frontier_Washer.pdf
Hope this helps.
Leaking Washer (Washer Repair)
by midget73 7/27/2014 3:27:00 PM(UTC)
by broonsparrow 11/30/2013 10:15:30 AM(UTC)
Leaking washer need advice (Washer Repair)
by GE Nightmare 10/5/2013 1:54:30 PM(UTC)
leaking washer (Washer Repair)
by ashkdaot 6/25/2013 6:23:18 PM(UTC)
by Jags 12/22/2012 8:37:52 AM(UTC)
by martha725 8/3/2012 2:11:37 PM(UTC)
leaking washer and won't drain (Dishwasher Repair)
by colt 11/6/2011 2:15:14 PM(UTC)
leaking washer (Oven Repair (including Ranges and Cooktops))
by cheery 11/5/2011 6:14:56 PM(UTC)
Leaking washer (Washer Repair)
by Crowell 9/6/2011 9:11:30 AM(UTC)
leaking washer during filling (Washer Repair)
by bonnetinsurance 8/10/2011 7:44:44 AM(UTC)
by 03svrider 6/9/2011 10:48:37 AM(UTC)
by rcarroll7703 6/1/2011 7:50:27 AM(UTC)
by Mrkis 1/30/2011 9:09:01 AM(UTC)
by Clueless101 12/27/2010 12:33:13 PM(UTC)
by wirenutt2 12/6/2010 9:44:26 PM(UTC)
