dryrprob
#1 Posted : Monday, October 15, 2007 4:26:13 PM(UTC)
dryrprob
The dryer works fine, but it won't stop running. The timer switch turns but then stops before it gets to the point on the dial where it's supposed to stop running.
ApplianceJunk
#2 Posted : Tuesday, October 16, 2007 4:58:08 AM(UTC)
ApplianceJunk
Hi,
Does the timer do this on all cycles?
dryrprob
#3 Posted : Wednesday, October 17, 2007 3:52:37 AM(UTC)
dryrprob
Yes, the dryer keeps running on all cycles. My wife said that the switch doesn't actually turn but remains stationary, and the dryer keeps running.
Thank you.
ApplianceJunk
#4 Posted : Wednesday, October 17, 2007 4:09:49 AM(UTC)
ApplianceJunk
If the timer does not advance to off during the timed cycle then I would replace the timer.
If the timer does not advance to off only on a automatic cycle then you have a different problem.
dryrprob
#5 Posted : Saturday, November 3, 2007 3:51:06 PM(UTC)
dryrprob
The timer advances on the Timed Drying cycle, but does not advance on the Dry-Miser cycles. This is a Whirlpool LET6638 electric dryer. I have tried replacing the timer switch and cleaning all the lint from inside the dryer. It still runs fine, but the timer switch does not turn off from the Timed Drying cycle, nor does it move on the Dry-Miser cycles. Any ideas?
Thank you.
richappy
#6 Posted : Sunday, November 4, 2007 1:38:34 AM(UTC)
richappy
Post back when you get a meter.
Whirlpool Dryer won't stop running (Dryer Repair)
by Dave1234567 10/19/2014 5:45:40 AM(UTC)
