2 Pages12>
castoju
#1 Posted : Thursday, April 28, 2011 3:22:51 PM(UTC)
castoju
I have replaced the pump on my combo waasher/dryer. The drain hose is clear, fills and agitates, but when it gets to the spin cycle I get no spin and no drain...what else should I trouble shoot?
#2 Posted : Thursday, April 28, 2011 8:07:32 PM(UTC)
Does the motor run when it comes to the drain/spin?
castoju
#3 Posted : Friday, April 29, 2011 4:41:39 AM(UTC)
castoju
Where do I check that or what should I listen for...when the machine stops the agitation I hear nothing else...is that when I should hear a motor?
#4 Posted : Friday, April 29, 2011 1:20:37 PM(UTC)
Sounds like the problem is a bad lid lock switch (#50 on the diagram). You have to remove the washer front panel to access it.
- The lid lock Part number: AP2108159
castoju
#5 Posted : Friday, April 29, 2011 2:12:06 PM(UTC)
castoju
Gene:
Is there a way I can test this...:confused: What does a switch have to do with spin cycle and drain? r/ Judy:(
#6 Posted : Friday, April 29, 2011 2:37:30 PM(UTC)
Judy,
The lid lock is a safety device. When it comes to the spin/drain, the power goes through the lid switch. It can be tested for continuity.
castoju
#7 Posted : Saturday, April 30, 2011 6:26:33 AM(UTC)
castoju
OK..will test for continuity...:cool: r/ Judy
castoju
#8 Posted : Sunday, May 1, 2011 8:55:43 AM(UTC)
castoju
Gene...I checked continuity on the switch...it is fine...then I checked power to the pump...no juice...what do I do next? When I close the lid to the machine it agitates...r/Judy
#9 Posted : Monday, May 2, 2011 2:35:01 PM(UTC)
Besides the switch there is a kind of lock motor which should lock the lid to supply back feed to the timer and start the pump and spin. The failure of this part is one of very common issues and I suggest just to replace it. In the worst case, if it would not fix the problem, you can just return the part (if you ordered it from APP).
castoju
#10 Posted : Monday, May 2, 2011 3:31:25 PM(UTC)
castoju
:confused: Would this be why there is no continuity in the wires on the pump...I tested the plug that comes out of the pump and the meter never moved or does the switch run power to the pump? Shouldn't I have continuity even though the switch is bad?
Guest (5)
Ge dishwasher will not drain (Dishwasher Repair)
by Handyman924 2/24/2017 8:05:27 PM(UTC)
maytag washer will not drain water (Washer Repair)
by mathy10544 12/13/2015 8:54:09 PM(UTC)
GE front load washer will not drain (Washer Repair)
by Sandmann01 6/22/2015 1:24:04 AM(UTC)
Washer will not drain (Washer Repair)
by Artnlp 5/3/2015 7:34:59 AM(UTC)
Washer will not drain in Normal cycle (Washer Repair)
by rober luck 4/20/2015 9:10:47 AM(UTC)
by charles140 10/10/2014 8:21:01 AM(UTC)
by hurler72 11/25/2013 10:59:35 AM(UTC)
topload washer will not drain or spin (Washer Repair)
by olac757@gmail.com 8/9/2013 9:08:21 PM(UTC)
Whirlpool dishwasher will not drain (Dishwasher Repair)
by PeterZ 8/6/2013 7:21:51 PM(UTC)
Washer will not drain or spin (Washer Repair)
by Fixit Dad 5/23/2013 4:26:49 PM(UTC)
by PepperVal 5/16/2013 8:36:29 AM(UTC)
Whirlpool Washer will not drain unless open and close lid (Washer Repair)
by twhistle 2/28/2013 8:16:58 AM(UTC)
Washer will not drain or spin, new pump and lid switch (Washer Repair)
by tangerine30680 1/26/2013 12:42:38 PM(UTC)
I replaced lid switch, still washer will not drain or spin (Washer Repair)
by dnschrstn 11/12/2012 12:39:16 PM(UTC)
washer will not drain before the spin cycle (Washer Repair)
by tondot 11/11/2012 5:32:56 PM(UTC)
2 Pages12>
