carey0413
#1 Posted : Thursday, April 21, 2011 7:26:18 AM(UTC)
carey0413
oven not heating on bake or broil
carey0413
#2 Posted : Thursday, April 21, 2011 7:30:40 AM(UTC)
carey0413
broiler wont come on nor the bake
carey0413
#3 Posted : Thursday, April 21, 2011 7:34:47 AM(UTC)
carey0413
oven will not get hot
Joe / APP Team
#4 Posted : Monday, April 25, 2011 7:26:35 AM(UTC)
Joe / APP Team
Carey,
Your range is a "gas" unit and has a spark ignition system.
Do the top burners spark and ignite ?
Can you see or hear the bake and broil burners clicking when you turn the oven ON ?
There are a couple of possibilities based on your post, beside checking fo loose connections and broken wires,
A bad DSI spark module,
Part number: AP3672576
Or a malfunctioning gas valve,
Part number: AP3866825
Good Luck,
James M SR
#5 Posted : Wednesday, April 27, 2011 7:28:24 AM(UTC)
James M SR
Model # MGR5775QDS Oven Element does not get hot
Joe / APP Team
#6 Posted : Wednesday, April 27, 2011 11:02:31 AM(UTC)
Joe / APP Team
James,
That model number has a "glow bar" ignition sydtem, it's a bit different than the previous model,
You need to remove the oven bottom panel, and program the bake cycle and observe the glow bar, it should start to glow in a few seconds, if it doesn't glow you need to check the black carborundum area to see if it's cracked or broken. if you have a multi meter you need to check the wires for 120 VAC from the control to the igniter.
If it does glow but never achieves a "white" hot appearance, the glow bar is weak and cannot trigger the valve switch to open and release gas, you can verify that procedure with a multi meter as well , there should be 3.2 to 3.6 VAC across the 2 wires on the bake burner valve.
Part number: AP4096758
JRV
#7 Posted : Friday, November 4, 2011 9:08:23 AM(UTC)
JRV
Hi, our oven has also been identified as having a malfunctioning gas valve. Do you have a schematic of where this part is located in the oven? I have reviewed the schematics on your website for this oven but cannot find this particular part.
Thanks in advance,
JRV
Joe / APP Team
#8 Posted : Friday, November 4, 2011 11:16:21 AM(UTC)
Joe / APP Team
Thanks in advance,
JRV
JRV,
There are three different ranges discussed in the post. Could you get us a model number so we can assist you more effectively. In most cases you can remove the oven racks, and oven bottom panel, to access the igniter and valve to test or observe the ignition process.
JRV
#9 Posted : Friday, November 4, 2011 11:31:17 AM(UTC)
JRV
Thanks for the quick response. The oven is a MAYTAG MGR5775QDS RANGE- S/C F/S GAS.
Thanks,
JRV
Joe / APP Team
#10 Posted : Friday, November 4, 2011 2:09:02 PM(UTC)
Joe / APP Team
Thanks,
JRV
JRV,
Thanks for the update.
The procedure to access the bake burner igniter is the same as the previous post:
Open or remove the oven door and racks. carefully remove the oven bottom panel, remove the flame spreader from the burner tube.
Program a bake cycle and temperature and observe the igniter for a glow and gas ignition.
As noted in the previous post, you can usue a meter to check the voltage on the wires at the safety valve, or observe the igniter, it should have a "white hot" glow/color to it in 60 seconds or less, if it's working proper.
Guest (5)
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 7:09:48 PM(UTC)
Thermadore PRG304GH oven not heating (Oven Repair (including Ranges and Cooktops))
by Guest 12/15/2022 6:58:50 AM(UTC)
upper oven not heating up to desired temp. it's off by about 50 degrees (Oven Repair (including Ranges and Cooktops))
by Guest 10/14/2022 12:50:23 PM(UTC)
Bottom oven not heating (Oven Repair (including Ranges and Cooktops))
by Castelle 1/21/2022 6:17:26 PM(UTC)
Monogram electric oven not heating (Oven Repair (including Ranges and Cooktops))
by Norploc 2/26/2021 12:56:03 PM(UTC)
Frigidaire GLEF378CBD - oven not heating (Oven Repair (including Ranges and Cooktops))
by canooten 3/20/2020 11:24:19 AM(UTC)
by deanowhitney 7/11/2018 11:22:38 AM(UTC)
GE gas oven not heating (Oven Repair (including Ranges and Cooktops))
by 1alembic 4/4/2018 5:59:05 PM(UTC)
Oven not heating when using convection (Oven Repair (including Ranges and Cooktops))
by ebonyclose 3/11/2018 7:37:25 PM(UTC)
Frigidaire Double Oven - Lower Oven not heating - Clicking (Oven Repair (including Ranges and Cooktops))
by RentAHubby 10/3/2017 8:42:44 PM(UTC)
Whirlpool Oven not heating (Oven Repair (including Ranges and Cooktops))
by proto8432 7/15/2017 10:07:03 AM(UTC)
Oven not heating up and gas smell in house (Oven Repair (including Ranges and Cooktops))
by DJKNY71 1/18/2017 7:06:47 AM(UTC)
Upper oven not heating, lower over works properly (Oven Repair (including Ranges and Cooktops))
by Greg2cycle 11/5/2016 9:50:34 AM(UTC)
Oven not heating properly (Oven Repair (including Ranges and Cooktops))
by Rentalmom5 9/14/2016 6:24:38 AM(UTC)
Whirpool Oven not heating (Oven Repair (including Ranges and Cooktops))
by cdfrerichs01 8/7/2016 10:55:06 AM(UTC)
