teresa in mo
#1 Posted : 14 years ago
teresa in mo
our refrigerator is not getting cold enough. My husband took the panel off in the freezer to look for the defrost switch and there was a block of ice. There was also frost buildup in the vent section of the lower shelf in the refrigerator section. He melted the ice with a hair dryer. He never could find a defrost switch or even a part number on the diagram online. It is cooling better, but still does not want to get below 48 degrees. This is with a pretty empty fridge. I am having alot of people here in the next couple of days as my daughter is getting married next weekend. I need to fill the fridge with food, but can't until this problem is resolved. Could you please tell me where the defrost switch on this model is, so my husband can determine if this is the problem?
#2 Posted : 14 years ago
Replacement parts for WHIRLPOOL ED5PHAXSQ00 REFRIGERATOR | AppliancePartsPros.com
The unit has an adaptive defrost, see how to force a defrost cycle in the tech sheet.
Sounds like you originally had a defrost problem if the block of ice was the evaporator coils. They must be iced/frosted over to the point where the fan cannot pull air through them.
But the unit should have worked properly for a week or so after the manual defrost.
Check the temperature in the freezer. It should be between 0 and 5 degrees F.
Is the evaporator fan running?
Is the compressor cycling or is it always on?
Is the damper (item 15 in Section 4) open?
Are the condenser coils and the condenser/compressor fan clean and is the fan running when the compressor is on?
There is a vent between the two sections about 2/3rds of the way down on the side wall. It it clear on both sides?
File Attachment(s):
ED5PH.pdf (632kb) downloaded 68 time(s).
Whirlpool Refrigerator not cold enough (Refrigerator & Freezer Repair)
by bsmcc 9 years ago
Frigidaire Refrigerator Not Cold Enough (Refrigerator & Freezer Repair)
by wing471 9 years ago
Freezer cold but not freezing, refrigerator not cold enough (Refrigerator & Freezer Repair)
by tyltea1st@charter.net 11 years ago
by mansoura 11 years ago
Freezer & Refrigerator not cold enough (Refrigerator & Freezer Repair)
by HFrank 12 years ago
Freezer and Refrigerator Not Cold Enough (Refrigerator & Freezer Repair)
by mahplane 13 years ago
by tonlam 13 years ago
Magic Chef Refrigerator Freezer work Refrigerator not cold enough (Refrigerator & Freezer Repair)
by tg06222 14 years ago
GE Profile Arctica Refrigerator Not Cold Enough (Refrigerator & Freezer Repair)
by Snap50 14 years ago
Kenmore refrigerator not cold enough (Refrigerator & Freezer Repair)
by Malinda 14 years ago
by davidwaynesmith 14 years ago
Freezer and Refrigerator not cold enough (Refrigerator & Freezer Repair)
by fionmay 14 years ago
Side by side refrigerator not cold enough (Refrigerator & Freezer Repair)
by Bhedman 14 years ago
Frigidaire side by side refrigerator freezer working refrigerator not cold enough (Refrigerator & Freezer Repair)
by SSOWDERS 15 years ago
by mfd 17 years ago
