Rick Roggentine
#1 Posted : Monday, November 3, 2008 5:44:57 PM(UTC)
Rick Roggentine
My dryer turns on, but it is not heating up. What could be the possible fix. Thank you.:rolleyes:
libertyappl
#2 Posted : Monday, November 3, 2008 6:30:45 PM(UTC)
libertyappl
Most likely the thermal cutoff or the element. If you have an ohm meter you can remove the rear paenl and check.
nat
kayakcrzy
#3 Posted : Tuesday, November 4, 2008 3:43:48 AM(UTC)
kayakcrzy
You also might want to flip your dryer breaker off and on a few times to make sure it did not trip on you. Just because the dryer runs, does not mean the dryer has full power, then check with Nat said. Tom ApplianceEducator.com
