dlynns47
#1 Posted : Thursday, April 21, 2011 9:43:39 PM(UTC)
dlynns47
This dryer blew a thermal fuse shortly after it was moved to a new house. relocated the exhaust vent 3 different times and blew thermal fuse shortly after each time. we have checked for shorted heater element. checked thermistor and resistance was within specs. I think the dryer has a heat control problem and I am inclined to replace the control module and thermistor, but I was hoping for another opinion before i coughed up 200 bucks for the parts. Any ideas. thanks for any help!!
sidfink43
#2 Posted : Sunday, April 24, 2011 5:09:10 PM(UTC)
sidfink43
The main reason a thermal fuse blows is something is blocking air flow from inside the machine to the vent pipe that goes to the outside, or something is blocking the vent pipe itself. It is also possibly there is a problem with the fan, had that the other day.
