Goldeneye32
#1 Posted : Sunday, November 2, 2008 3:28:45 PM(UTC)
Goldeneye32
I have a whirlpool washing machine that will fill with water but will not agitate or spin. I have check the lid switch and wired it together to eliminate the lid. I as so check the capacitor which also checked out good. The timer sounds weird when I pull out the nob. The timer has never made this sound before, it sounds like something is grinding. When I move the timer between the different cycles trying to get it to work, sometimes the motor will humm. This leads me to think the motor is bad. I also removed the water pump from the motor as well. please Help.
timer number:3955499
Motor number: 8528157
v2k04
#2 Posted : Sunday, November 2, 2008 4:30:49 PM(UTC)
v2k04
Remove The Motor And See If The Coupler Is Broke
Goldeneye32
#3 Posted : Sunday, November 2, 2008 5:41:05 PM(UTC)
Goldeneye32
Coupler is Good. Motor isn't spinning when timer is put out. But isn't motor locked up
Goldeneye32
#4 Posted : Sunday, November 2, 2008 5:42:30 PM(UTC)
Goldeneye32
Sorry, Motor isn't locked up
v2k04
#5 Posted : Sunday, November 2, 2008 5:49:20 PM(UTC)
v2k04
try hooking just the motor to wire harness not mounted to machine with lid switch jumpered in spin will it run?
richappy
#6 Posted : Monday, November 3, 2008 2:21:07 AM(UTC)
richappy
I would pull the cover off the timer and check for burnt contacts.
GE Dryer - Motor or Timer? (Dryer Repair)
by mwatson2 12/28/2013 1:01:20 PM(UTC)
Kenmore Elite - motor or timer? Help! (Washer Repair)
by flenn 10/27/2012 5:06:22 PM(UTC)
Replace motor or timer? (Washer Repair)
by Anil Kollipara 4/25/2010 5:12:15 AM(UTC)
