Oven won't light, broiler will. If I tap on the gas valve, it will sometimes let the gas flow, and it will light. not sure how to get an amp reading off igniter. valve is 3.3 to 3.6 amps. Any thoughts?
Rank: Administration
Groups: Joined: 7/18/2007(UTC) Posts: 799
Hi marc, The easiest way to test is with one of these. But there is really no need for that. Replace the igniter and you should be back in business. You can purchase the original Whirlpool oven igniter your model calls for or you can save about $45 and get a Frigidaire oven igniter instead. The igniters are almost identical and either one will work just fine. Breakdown diagrams for Model SF367PEYN7Let me know how it goes.
Thank you! I let you know what happens!
I went with the Frigidaire igniter, arrived today, took 15 min to install, and the oven lights great! Thanks for your help!
Great to hear that, Marc! Thanks for letting us know.
