I am replacing the electronic clock timer in my range with a Harper-Wyman manual thermostat model 6700G001B. The controller has the following spade connector posts: PL, L1, L@, COM3, BKE2, and BRL2.
My local friendly appliance repair guy told me to make the following hook-ups: One hot post of the terminal block to L1. The other hot post of the terminal block to L2. One wire from COM3 to the right side broil element and another from COM3 to the right side bake element. (Right side as I face the work at the back of the stove.) Wire from BRL2 post to the left side broil element connection. Wire from BKE2 to left bake element connection.
I am also told to connect the two wires for the indicator light (250 V) to the PL post and the COM3 post.
My question: Where do I connect the neutal wire?
