cnjcampione
#1 Posted : Saturday, November 1, 2008 5:46:15 AM(UTC)
cnjcampione
The fan on my Jennair downdraft cooktop (black) has quit. I have oredered a switch and new knob from this site. How is the old switch removed? I see two screws holding the switch assembly to the frame but when I removed the screws, the assembly did not lift out. Does anyone have some ideas before I snap somthing off. Thanks..Charlie
#2 Posted : Saturday, November 1, 2008 5:43:31 PM(UTC)
Pull the panel outward and then lift it up.
cnjcampione
#3 Posted : Saturday, November 1, 2008 8:27:12 PM(UTC)
cnjcampione
Gene,
Thanks for the info. When I take out the two screws, the only way it can go is straight up then out but it will not come up for some reason..Charlie
#4 Posted : Monday, November 3, 2008 10:56:49 AM(UTC)
Charlie,
The model number you posted does not come up. Verify and repost it, please.
cnjcampione
#5 Posted : Monday, November 3, 2008 11:54:59 AM(UTC)
cnjcampione
Gene,
Thanks for caring. My model number is JED8430ADB Sericl Number 19132422EL. When I was trying to find the part number for the fan switch, I also had trouble pulling it up. I called JENNAIR and they used JED8430ACW to pull it up but said it was the same mondel only mine was black. I hope this helps..Charlie
#6 Posted : Monday, November 3, 2008 3:15:07 PM(UTC)
Charlie,
According to the break down diagram looks like you have to remove the main top to access the switch what requires the cooktop removal from the countertop.
cnjcampione
#7 Posted : Monday, November 3, 2008 6:07:12 PM(UTC)
cnjcampione
Thanks Gene. The part will arrive any day now and I think I will remove the top to install it. Thanks for all your help..charlie
#8 Posted : Monday, November 3, 2008 7:51:01 PM(UTC)
Keep us posted.
