Voltage at L1 to Neutral is 120v, Voltage at L2 to Neutral is 120v, Voltage at L1 to L2 is 240 but voltage at L1 to Chassis Ground is 180-200v & L2 to Ground is 70v. What is happening. This Unit went dead after self distruct (cleaning) nothing works, all fuses are good.
Originally Posted by: Earl Dryer ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Voltage at L1 to Neutral is 120v, Voltage at L2 to Neutral is 120v, Voltage at L1 to L2 is 240 but voltage at L1 to Chassis Ground is 180-200v & L2 to Ground is 70v. What is happening. This Unit went dead after self distruct (cleaning) nothing works, all fuses are good. See diagnostics : http://www.servicematters.com/docs/wiring/wiring_main.htm
I assume that you want me to see something in the schematic, so lets assume that I there is a shorted Cap in the filter circuit, you think that may be it, by the way L2 is the high leg because I only 70V to the primary on the Xfmr & 0 on the secondary.
There seems to be the trouble, nothing on the secondary of the transformer. Let's run a step by step and let us know what are the results.
So what was the outcome? By the way,secondary of this transformer is DC
:D Aw come on now. What was the outcome ?
Maybe that what the problem is, this transformer is missing the rectifier circuit to convert the the low voltage AC Give me a break any rectification is going happen on the board. FYI The Voltage on the secondary is approx. 25-30v AC!
Was just curious as to what you have found out as I brought it up at a meeting, and no one could could come up with a reasonable answer.
I'm kinda curious if you get the same readings at the outlet without stove being plugged in
Those readings were normal, That is why I was Questioning posibily the suppressor or filter circuit maybe the culprit as far as the readings to ground. I know that the low voltage transformer is bad, I have an open secondary but I only have 80v to primary so even with a good Xfmr my LV output is going to probably pretty low too.
