tsmith49
#1 Posted : Wednesday, April 13, 2011 4:04:53 PM(UTC)
tsmith49
everything on stove top works burners clock timer speed bake lights even the temp works for oven timer light but when when hit the start button
it lights up but none of the elements get red or come on the oven is cold
please help lost oven man.
#2 Posted : Thursday, April 14, 2011 3:48:26 AM(UTC)
Replacement parts for FRIGIDAIRE FEF376ASJ Frigidaire/electric Range | AppliancePartsPros.com
Here is your operators manual
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257123en.pdf
And the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316255319.pdf
If you mean by lights up that the unit comes ready then it could be your temperature sensor re: the unit thinks that it is already at operating temperature so does not turn the elements on.
Here is a good link.
http://www.applianceaid.com/elecrange.html
Check out 7, 8, 20 and 21.
If the unit stays in preheat then odds are that the control board is toast but I would check the wiring from the board to the elements just to be sure that it is not just a bad wire/connection.
Be sure to unplug the unit when working on it.
Oven not baking at correct temp (Oven Repair (including Ranges and Cooktops))
by Tracylsmith 3/12/2009 1:25:46 PM(UTC)
Oven Not Baking (Oven Repair (including Ranges and Cooktops))
by Oakley 10/30/2008 11:05:26 AM(UTC)
Oven not baking (Oven Repair (including Ranges and Cooktops))
by junkyard38 1/25/2008 5:56:55 PM(UTC)
