erichmann
#1 Posted : Monday, April 11, 2011 6:06:40 PM(UTC)
erichmann
This machine starts normally, but will not go to spin cycle automatically. It will just continue to agitate through the spin and rinses, until it shuts off. When the control/timer dial gets to "Spin", or past it, if you push in on the the knob, which stops the machine action, then pull it back out, it spins. It will then start to fill for another rinse, but, it will still skip the next spin, and later shut off when the timer dial gets to "off"; if you then depress the knob, turn it to any "Spin" position, and pull the knob out, it will again spin for the duration of that spin cycle. This works every time. Every other feature seems to work (it drains, it fills, it releases fabric softener, etc.). One time when it delayed spinning, I lifted the door, let it close, and it started spinning. But that doesn't work every time.
I already replaced both drive belts, because they were old. Do I need a new timer? Or, could it just be that door lid switch? Or??
richappy
#2 Posted : Tuesday, April 12, 2011 7:06:08 AM(UTC)
richappy
I would pull the cover off the timer and check the contacts, probably bad, if so, order a new timer AP4026544
erichmann
#3 Posted : Tuesday, April 12, 2011 9:35:58 AM(UTC)
erichmann
Thanks for the reply, and I'll try that. The more I monkeyed with it yesterday, I also noticed that contacts for the rinse and spin functions seemed displaced, that is, I had to turn the control past the "spin" indicator, then engage it, to get it to spin. If I point it directly at Spin, it fills to start another rinse. I have to press the knob, and turn it another several degrees before it will spin.
So, I wonder if that also indicates some worn or displaced contacts in the timer. I will look, first, then probably have to order one. Better than a new washer or a $350 service call on an old washer.
Thanks again.
richappy
#4 Posted : Tuesday, April 12, 2011 1:46:52 PM(UTC)
richappy
Check to make sure the motor is not overheating. If it is, the timer contact leaf springs may be warped and the contacts badly damaged. If so, probably not worth fixing.
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 10/1/2021 10:08:04 AM(UTC)
Maytag Washer won't Spin just Hums (Washer Repair)
by bnweth 1/4/2017 8:29:35 PM(UTC)
maytag washer won't spin fast (Washer Repair)
by benp1 12/21/2016 5:14:31 PM(UTC)
Maytag Washer Won't Spin (Washer Repair)
by DJames 9/6/2015 5:36:58 PM(UTC)
Maytag Washer won't spin. (Washer Repair)
by spectre_ 1/19/2015 5:24:12 PM(UTC)
Maytag washer won't spin fast enough (Washer Repair)
by dster 1/6/2014 7:06:08 AM(UTC)
by ProfKenn 11/21/2013 6:18:07 PM(UTC)
Maytag washer won't spin (Washer Repair)
by ma-henry 11/14/2013 8:43:10 AM(UTC)
Maytag washer won't spin and there is a burning smell (Washer Repair)
by figureguy 4/6/2013 11:59:49 AM(UTC)
Maytag Washer won't spin sometimes! (Washer Repair)
by fixit4meNOW 3/21/2013 11:11:25 AM(UTC)
by Hupper 10/10/2011 12:48:31 PM(UTC)
by treehugger 8/25/2011 12:44:37 PM(UTC)
by randowhite 3/31/2011 11:45:17 AM(UTC)
Maytag Washer Won't Spin or Agitate (Washer Repair)
by scott805 11/16/2010 12:09:40 PM(UTC)
Maytag Washer won't spin (Washer Repair)
by starkdr1 2/27/2010 10:05:08 AM(UTC)
