I have a refridgerator is giving out 30 degrees in the refridgerator and it is supposed to stop at 40. the compressor stops every 20 minutes but the temperature is staying at 30 degress? I replaced the cold control, defrost timer and replaced the defrost thermostat what else could be wrong with it?
Measure the freezer temperature and post, should go down below ten degrees.
