bienicma
#1 Posted : Wednesday, March 30, 2011 12:39:44 PM(UTC)
bienicma
When you run the dryer you'll here the "click" the igniter will glo and the flame will come on. But the problem is it won't stay on. It only remains on for 5-10 seconds.
I was told the problem could have to do with airflow. I've removed the front panel on this dryer and cleaned it out. I cleaned out all of the "caked" lint through the entire machine. We even took off the rear exhaust.
After reading, I've come up on opinions of valve solenoids or a flame sensor. I'm leaning toward the flame sensor, but I'm not 100% sure and need the assurance.
#2 Posted : Wednesday, March 30, 2011 2:16:07 PM(UTC)
Make sure the blower wheel is not slipping on the motor shaft.
If there is nothing wrong, replace the high limit thermostat (#6 on the diagram).
- The blower wheel Part number: AP4062362
- The high limit thermostat Part number: AP4290151
Here are the breakdown diagrams and Replacement parts for AMANA LG8409W2 DRYER- GAS | AppliancePartsPros.com
P.S. What is the color of the flame when it's on?
bienicma
#3 Posted : Wednesday, March 30, 2011 2:27:17 PM(UTC)
bienicma
Thanks Gene. The flame is mostly blue and the motor wheel is turning OK. I've been running the dryer with the front panel off for now. Thanks a million!!! :) :) :) :) :)
#4 Posted : Wednesday, March 30, 2011 2:37:29 PM(UTC)
bienicma
#5 Posted : Thursday, April 7, 2011 10:40:53 AM(UTC)
bienicma
Hi Gene,
I replaced the thermostat. My result is almost the same as before. The flame now looks more blue, but is still going on and off. The only difference from before is after the flame shuts off there's a second click and the dryer seems to be a little hotter inside than before. Bad solenoids?
Thanks,
Mark
#6 Posted : Thursday, April 7, 2011 12:15:20 PM(UTC)
Mark,
If the flame goes on every time when the igniter glows but it does not stay on long enough (between 40 sec to 60 sec), then the flame sensor is the next part to replace. It can not be tested instrumentally in such situation but it can be the culprit.
- The flame sensor Part number: AP2910747
