was working fine.
now machine will fill ok.
siphon it out, try again and it fills but that is all.
wont do anything else.
can't hear timer motor running.
have 110 volt power to machine.
have schematic
have digital meter and know how to use it on cars and computers, but not on washer timer.
maybe the water sensor level is bad.
how do i find the water level sensor ?
What ya gotta do is blow out the hose that is fitted on the lower end of the the tub and goes up to the top to the water level switch. Remove the hose (at the water level switch) and blow out the trash and reinstall it good and snug, dump the water out and retry Kimosabe:D IM optics.pdf (50kb) downloaded 9 time(s).SublimeMasterJW attached the following image(s):
You did say it was filling Ok, and doing nothing. Have we checked the lid switch assembly, there is a fuse, and 2 switches. I believe your problem is right there. You can purchase the whole assembly. Tom ApplianceEducator.com
