I turned the microwave on and heard a pop followed by a humming sound. Now it doesn't heat. I have power, the light comes on, the dish rotates along with a humming sound, no heat. I was thinking that maybe a fuse blew so I removed the panel but did not see any fuses. HELP!:confused:
Rank: Administration
Groups: Joined: 7/18/2007(UTC) Posts: 799
The loud pop does usually indicate a bad rectifier. Make sure to 1. Turn off power to the microwave first and 2. discharge the capacitor before attempting any repairs. - Replacement rectifier
So this does not sound like an easy job, what do you think? would it just be easier to buy another?
Actually, it's a fairly simple job, as long as the safety rules are followed re: disconnecting the power and discharging the capacitor. But, if you don't feel comfortable working on a microwave, please don't. Getting shocked from a high voltage capacitor could mean serious heart problems or even death. Rectifier is number 1 on this diagram and capacitor is number 2, right behind the control panel. Here is a page that among other things shows how to discharge a capacitor. It's a long page and has lots of info on it, so I would suggest doing a search for the phrase How To Discharge The High Voltage Capacitor (click Control and F for search while on that page).
How do you know if it's the rectifier or the cap? I did 12volt for alittle over 9yrs and have seen some caps go bad. Nothing internally looks bad here. Thanks
Thanks understood the hole. Now does the cap need to be discharged before taking a ohm reading? Didn't see any holes in the diode, but they dont give you a lot of area for working.
Didn't see the link at the bottom. Got it. Thanks
