butch2b4
#1 Posted : Monday, April 4, 2011 1:17:52 AM(UTC)
butch2b4
Hi,
My Kenmore model # 665.17751790 dishwasher stopped in mid cycle. I checked my circuit breaker, it was fine, flipped it off and them back on. There are no lights nor any indication of electrical current on dishwasher.
Checked with Sears online, can't find a thermal fuse for this unit. Is there one? Is there a circuit/control board? How would I check that?
If you were me, which right now you're probably glad you're not, what would you do? What should I check next? Is there any hope for this unit?
It's never had one problem, now it's DOA.
Thanks for any help.
#2 Posted : Monday, April 4, 2011 2:29:36 AM(UTC)
Also it is the only easiest way to check the power.
First check that the power is OK.
Next check the wirenuts which usually connect the unit to power.
Then unplug it or trip the breaker and use ohms to check the switches.
Then check that the door switch (you may have two of them) are closing when the latch is latched.
Maytag dishwasher stopped mid cycle (Dishwasher Repair)
by joestehlingq 10/22/2012 10:07:06 AM(UTC)
bosch dishwasher stopped mid cycle (Dishwasher Repair)
by tomsidle 10/22/2008 1:58:52 PM(UTC)
