rumali
#1 Posted : Saturday, February 9, 2008 4:54:57 PM(UTC)
rumali
Hello,
I need to replace the plastic water line/tube that runs up the freezer door up to the water/ice dispenser - because it is cut at the bottom corner of the freezer door.
Anyone have a diagram and/or advice on how to remove/replace it?
Thanks!
Rani
#2 Posted : Monday, January 5, 2009 3:06:33 PM(UTC)
Rani
I am having the same problem, I need to replace the water line going into the freezer door. I was wondering if you ever found a way to replace the water line. Thanks
mcload
#3 Posted : Sunday, April 3, 2011 4:00:49 PM(UTC)
mcload
I am having the same problem with aGE model number GSS25WGPDWW.
I have replaced the valve solenoid.I have left the freezer off with the door opened for over three hours. I evenconnected a bicycle pump to the tube where it enters the freezer door, andpumped it up to 50psi. I have checked three different fix it yourself websites. No one has been able to explain how to replace the tube inside a GEfreezer door.
