radgy
#1 Posted : Thursday, October 11, 2007 11:23:34 AM(UTC)
radgy
repalced igniter,now it wont bake...broiler will come on...goes off in on(think it is supposed to do that?)i found this looking on the net:
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
anybody now how to check to see if its set to automatic/how to change to manual?...or any other ideas?
richappy
#2 Posted : Friday, October 12, 2007 1:33:36 AM(UTC)
richappy
You will need a meter to check things, post back when you get one.
radgy
#3 Posted : Friday, October 12, 2007 6:21:31 AM(UTC)
radgy
what kind of meter?whats it called,i will find one
richappy
#4 Posted : Friday, October 12, 2007 6:59:02 AM(UTC)
richappy
You can get one at Lowe's. Digital one with amprobe,ohms and ac voltage will do.
Whirlpool Gold oven wont bake, turn it on and reads LO (Oven Repair (including Ranges and Cooktops))
by GWHunter 5/6/2015 9:48:20 AM(UTC)
Oven Wont Bake, Just Broil (Oven Repair (including Ranges and Cooktops))
by malloysix 6/4/2011 5:16:30 AM(UTC)
Kenmore oven wont bake, but will broil and cooktop works (Oven Repair (including Ranges and Cooktops))
by pontiac_78_ta 6/27/2009 1:56:47 PM(UTC)
frigidaire oven wont bake (Oven Repair (including Ranges and Cooktops))
by gladystucker@charter.net 3/15/2009 12:58:37 PM(UTC)
Oven wont Bake (Oven Repair (including Ranges and Cooktops))
by free1380 11/5/2008 8:11:24 PM(UTC)
Electric Oven wont bake, broil, or clean (Oven Repair (including Ranges and Cooktops))
by utnuc 7/6/2008 1:40:00 PM(UTC)
