jrob
#1 Posted : Wednesday, October 10, 2007 6:03:29 AM(UTC)
jrob
just replaced the oven control module still getting error code PF I have the 240v
to the board the question i have, would the keyboard(touch panel) cause this problem, it is attached to module through a membrane connector is there a way to test these switches?
Pegi
#2 Posted : Wednesday, October 10, 2007 1:49:10 PM(UTC)
Pegi
Sounds like you are getting "noise interference", there are several service pointers addressing this problem but none with model numbers that match yours, might call Whirlpool with your model and serial to see if they know which kit may be available for your unit...
jrob
#3 Posted : Thursday, October 11, 2007 4:56:58 AM(UTC)
jrob
sounds like your saying keypad is not the problem customer says when power outage occurs stove always came back with PF when power restored, until he pushed the cancel button so i take it the keypad OR membrane if defective we would be getting this PF and cannot clear it
richappy
#4 Posted: : Friday, October 12, 2007 1:37:11 AM(UTC)
richappy
Remove keypad ribbon cable and turn power on, if now no problem, replace keypad.
Click on your model # to get it.
jrob
#5 Posted : Friday, October 12, 2007 6:10:47 AM(UTC)
jrob
yes but with membrane unplug i get the E1 F2 Error code which means keytail unpluged but before that, PF is there for a few seconds so how do you figure that out?
richappy
#6 Posted : Friday, October 12, 2007 5:29:38 PM(UTC)
richappy
All the symptoms show a stuck keypad. I would replace it.
stove top works/clock on/oven controls dead (Oven Repair (including Ranges and Cooktops))
by jrob 9/17/2007 5:55:24 AM(UTC)
