Oven will not light, clicks twice but won't light. Replaced control panel still getting same error code E0 F0. What do I change next? Top burners and clock works.
I would replace your bake igniter if that's your failed area. Click on your model # to order.
richappy,
I failed to mention in my first posting that not only does the oven not work but niether does the broiler. I think I need a part that is common to both the broiler and the oven. - Sorry I didn't get all the info out the first time. Could both igniters be bad at the same time?
wyoming joe
I would pull out your service sheet, located on the frame next to the bottom drawer, and see what the error codes mean.
