2 Pages12>
kilowat
#1 Posted : Tuesday, September 18, 2007 9:35:07 AM(UTC)
kilowat
oven has quit working, the the clean cycle will work. i have taken the igniter out plug it into 110 volts it glows bright red almost white
can the igniter still be bad??
Admin / APP Team
#2 Posted : Wednesday, September 19, 2007 11:52:44 AM(UTC)
Admin / APP Team
Rank: Administration
What happens when you turn the oven on and set it to BAKE? Does the igniter start to glow?
kilowat
#3 Posted : Wednesday, September 19, 2007 12:28:52 PM(UTC)
kilowat
nothing, only the clean cycle will work ran that also
richappy
#4 Posted : Thursday, September 20, 2007 2:18:05 AM(UTC)
richappy
Set the control to bake, check the schematic, and check the bake output wire from the control, if no voltage, you probably have a bad control module. Before replacing, check the resistance of the oven sensor, if way off it's room temperature resistance( should be around 1Kohm) replace it. Click on your
Model # to get the part #.
kilowat
#5 Posted : Thursday, September 20, 2007 6:25:52 AM(UTC)
kilowat
thanks will try that, i was in the navy in 65/69 aviation electronic been long time
lol
kilowat
#6 Posted : Thursday, October 11, 2007 8:29:52 AM(UTC)
kilowat
got around to measuring the ohms on the digtal meter it reads .22 k ohms
richappy
#7 Posted : Thursday, October 11, 2007 10:11:18 AM(UTC)
richappy
Sounds bad, just order a new one by clicking on your model # and getting the part #.
kilowat
#8 Posted : Thursday, October 11, 2007 5:04:30 PM(UTC)
kilowat
the local maytag dealer had the igniter changed it out still want come on
richappy
#9 Posted : Friday, October 12, 2007 12:20:16 AM(UTC)
richappy
You changed the oven sensor or the igniter??
kilowat
#10 Posted : Friday, October 12, 2007 10:16:07 AM(UTC)
kilowat
changed igniter #12400035
i think i read the ohms on the igniter and and posted, not the oven sensor!!!
took out the oven sensor it read 1000 ohms
Crosley Gas Oven igniter? (Oven Repair (including Ranges and Cooktops))
by gospelguy 1/18/2018 1:02:51 PM(UTC)
Confused about replacing oven igniter Frigidaire (Oven Repair (including Ranges and Cooktops))
by artemis 12/4/2017 9:24:14 AM(UTC)
Oven Igniter will not activate (Oven Repair (including Ranges and Cooktops))
by MDThompson 12/27/2016 4:05:57 PM(UTC)
Oven Igniter for Capri (Sears) Propane Stove (Oven Repair (including Ranges and Cooktops))
by BumpyKnuckles 11/26/2016 6:38:15 PM(UTC)
is the oven igniter supposed to go out after oven lights? (Oven Repair (including Ranges and Cooktops))
by dterrasi 12/6/2014 1:54:14 PM(UTC)
Oven igniter glows red but does not heat (Oven Repair (including Ranges and Cooktops))
by TeamCeisel 9/25/2012 4:21:07 PM(UTC)
Oven igniter Magic Chef (Oven Repair (including Ranges and Cooktops))
by Mar4130 8/14/2012 9:26:19 AM(UTC)
Bosch oven igniter repair (Oven Repair (including Ranges and Cooktops))
by soonerhokie 9/4/2011 11:27:12 AM(UTC)
Replaced Oven Igniter Melted Wire Nut (Oven Repair (including Ranges and Cooktops))
by Edward A 6/7/2011 3:44:07 PM(UTC)
oven igniter on, no heat (Oven Repair (including Ranges and Cooktops))
by alelessbee 4/28/2011 8:47:52 AM(UTC)
GE Oven Igniter coil replacement (Oven Repair (including Ranges and Cooktops))
by jeffcorona 1/6/2011 9:35:05 AM(UTC)
How do I replace the oven igniter on a GE XL44 Range? (Oven Repair (including Ranges and Cooktops))
by rwbarrett 12/20/2010 8:47:55 AM(UTC)
Oven Igniter (Oven Repair (including Ranges and Cooktops))
by LCPierce 12/9/2010 8:42:47 AM(UTC)
Tappan oven igniter installation (Oven Repair (including Ranges and Cooktops))
by Just George 11/24/2010 9:44:06 AM(UTC)
Replace gas oven igniter (Oven Repair (including Ranges and Cooktops))
by JRhein 11/15/2010 7:07:22 AM(UTC)
2 Pages12>
