I Moved Into A New House And Found The Ice Maker Was Leaking.after Changing The Water Supply Line It Continued To Leak,just Not As Much.what Else Could Be The Problem.the Leak Is In The Inside.
If its leaking inside the freezer, replace the water inlet valve on the back of the refer.
