Ok I seem to have located the problem.. But I’m in need of assistance.. I removed the Belt and check all the pulleys, I notice the motor pulley rotates with some tension, and not smooth - I also notice that when I 1st tried to turn the motor pulley it was wedge against the metal of the washer.. So when I Tired to turn it - I t made this load squeaking noise, then stop turning.. Then when I move the motor away from the metal It turn freely but when I let it go - it gets wedge right back against the metal and Either turns slowly or not at all… how can I fix this problem with out buying new motor.
Probably missing motor spring AP4027842, just look for it.
