pdl122000
#1 Posted : Wednesday, October 15, 2008 3:39:11 PM(UTC)
pdl122000
Please help, I have lint covering my clothes. Iwashed out lint screen, then took the back off and cleaned it out. I also added new vent pipe, then started dryer with the back off, and squirel cage is turning. dont know what else to do. thanks in advance.
v2k04
#2 Posted : Wednesday, October 15, 2008 6:08:03 PM(UTC)
v2k04
Lint on clothing is actually created in the washer from the abusive effects the agitator has on them and lint is fiber coming out of the fabric so as you can see clothes don't last very long with top load washers.So maybe the problem is in the washer I know on Kenmores the lint screen on the bottom of the wash tubs(WHICH IS SUPPOISE TO BE SELF CLEANING) get plugged up and dont work very well also cheap clothes produce more lint. Try a gentler cycle on the washer and see if that helps also make sure your lint screen on the dryer isn't plugged you can tell this by holding the lint screen under a faucet and if it holds water it's plugged with the wax off the dryer sheets like bounce you can clean them with a moderately hard bristle cleaning brush.
pdl122000
#3 Posted : Friday, October 17, 2008 3:56:48 PM(UTC)
pdl122000
Thanks V2Q04, Please tell me how to find the lint screen on the washer it's a Kenmore. Model no. 22642100, Ser. CP2420569, and also how to clean it. One more question, I have been using this washer and dryer for five years now, when I dry whites lint screen has always been full, but now nothing it's all on my clothes. Thanks for any help in advance.
v2k04
#4 Posted : Friday, October 17, 2008 5:08:51 PM(UTC)
v2k04
Lets go back to the dryer pull the back ofit back off, and remove the screws that attach the blower housing there will be four of them and lint piles up in the bottom of if after you remove the 4 screws pull it out and reach your hand up there and dig out the lint wear a pair of gloves cuz the edges are sharp. Also did you cleen the dryer lint screen? and do the test with water? It's sounding like the dryer is totally plugged also run it with the vent off how much air flow is coming out of the exhaust? The washer screen is hard to get to. The tub will need to be removed
Guest (5)
Excessive lint on clothes - Whirlpool (Washer Repair)
by Jeffrock 5/14/2017 5:57:21 PM(UTC)
Lint on clothes (Washer Repair)
by williaeb 11/5/2012 10:30:42 AM(UTC)
RCA washer leaves lint on clothes (Washer Repair)
by relish27 11/6/2011 6:53:40 PM(UTC)
Washing machine leaving lint on clothes (Washer Repair)
by dalek 6/9/2011 1:55:05 PM(UTC)
by radrv6 5/19/2011 10:25:51 AM(UTC)
by David Blair 2/10/2010 6:39:56 AM(UTC)
