2 Pages12>
taylor49
#1 Posted : Tuesday, October 14, 2008 5:28:38 PM(UTC)
taylor49
took brake off tub spins easy,help
#2 Posted : Tuesday, October 14, 2008 7:16:53 PM(UTC)
Can you be more specific on the problem, please?
taylor49
#3 Posted : Wednesday, October 15, 2008 2:45:19 PM(UTC)
taylor49
i took the brake off and tub spins easy do you think the brake is the probelm?
#4 Posted : Wednesday, October 15, 2008 2:47:52 PM(UTC)
What was the original problem?
taylor49
#5 Posted : Wednesday, October 15, 2008 2:49:24 PM(UTC)
taylor49
it would not spin
#6 Posted : Wednesday, October 15, 2008 2:56:20 PM(UTC)
Did you check the belts and belts tension first? This is most common issues.
taylor49
#7 Posted : Wednesday, October 15, 2008 2:59:43 PM(UTC)
taylor49
I replaced both belts and still wouldn,t spin even went i slid the motor back it would pull motor down so i took brake off to check bearings they are in good shape the tub will spin freely with brake off what do you think the paoblem is please help . thanks
#8 Posted : Wednesday, October 15, 2008 3:08:49 PM(UTC)
One of things causing such washer not to spin is break assembly is not disengaging.
You can find the complete instructions and learn how your washer works from the Service manual.
Here are the break down diagrams for the Maytag washer Model LAT9206BAE
taylor49
#9 Posted : Thursday, October 16, 2008 3:52:43 PM(UTC)
taylor49
thanks gene i order a new brake pully a bearing hope this will fix it
magician59
#10 Posted : Friday, October 17, 2008 8:23:41 AM(UTC)
magician59
Did you check the lid switch?
2 Pages12>
