My dryer squeaks when the drum turns. everything works fine but the squeaking noise is very annoying. I've checked the felt seal and the drum belt and I can't figure out what the problem is. Can anyone help me please?
hello,
Going through some issues with my dryer of which squeaky while turning is one. I opened front end and took out tensioner and cleaned completed with dawn dishwash stuff returned tensioner and so far it has been quiet as a mouse.
For Ruben: Remove drum by lifting rear ball out of the socket. Use high temperature grease in the socket, that should fix it. Click on your model # for assembly info or parts.
