What is an appropriate oil to replace whirlpool transmission oil? I found the plastic gear shredded inside the transmission and the oil is ten years old as well, probably time to replace it. :D
toddpole The part number for the Whirlpool transmission oil is AP3072960 For the future references following is the break down diagram for the Whirlpool washer Model LXR7144EQ1 Good luck. Gene.
