Lynn Borum
#1 Posted : Thursday, October 9, 2008 9:57:51 AM(UTC)
Lynn Borum
can you help me
I am trying to find out how and where to light the oven on a gas cook stove
all of the burners work fine on top
i just can't seem to make heads or tails out of the lighting instruction inside the door inside the oven
Lynn Borum
#2 Posted : Thursday, October 9, 2008 10:00:34 AM(UTC)
Lynn Borum
trying to find out how to light gas stove
v2k04
#3 Posted : Thursday, October 9, 2008 10:01:34 AM(UTC)
v2k04
next to the main burner is a pilot assy. unless it has a glowcoil
Lynn Borum
#4 Posted : Thursday, October 9, 2008 10:01:57 AM(UTC)
Lynn Borum
:confused:
v2k04
#5 Posted : Thursday, October 9, 2008 10:07:06 AM(UTC)
v2k04
the burner and pilot are easier to get to by removing bottom plate in oven there are usually two screws on either side then the plate lifts up and out then under that is usually a spreader plate that when the flame hits it causing the flame off the burner to get wider remove the plate usually its held on buy a 3/8 nut in the center then you can see right on top of burner and pilot assy
