2 Pages12>
rainbonh
#1 Posted : Monday, February 14, 2011 11:49:47 AM(UTC)
rainbonh
Timer was not moving. replaced timer with new one ($85). Found while researching internet there is something else that can control the timer in all repects like a moister sensor. A moister sensor does not show for my machine. Is there some other kind of sensor. Wife wants a new machine now!!!!!!!
#2 Posted : Monday, February 14, 2011 5:41:07 PM(UTC)
Make sure the dryer vent is clean all the way through the vent outlet and there are no any air flow restrictions.
If there is nothing wrong, replace the cycling thermostat. If you need the correct part number for the cycling thermostat, post the serial number of the dryer.
rainbonh
#3 Posted : Tuesday, February 15, 2011 2:37:58 PM(UTC)
rainbonh
Hi Gene
I cleaned the vent pretty good with a vent brush
As you requested I am submitting the Md# NDG5800AWW and the
ser# 10119897EC. I found a heater,thermostat and a thermostat in the schematics but no cycling thermostat. Thanks Tom
Wife says: clothes taking to long to dry. what else can I change other then the timer and cycling thermostat I did. I also ordered and replaced the thermostat that the cycling thermostat fits into. Still have problems. Is there anything else?? I will throw it out before I call someone to fix something I should be able to do.
#4 Posted : Tuesday, February 15, 2011 3:11:40 PM(UTC)
Originally Posted by: 123laundry Go to Quoted Post
The problem could be the door lock assembly. door does not lock properly, therfore does not send the signal to the timer, and timer is not moving, because it is not getting the command from the door that it is closed, so start the process of washing. how about that?
You did not read Toms question carefully. We are talking about the problem with his dryer, not washer. If the dryer tumbles then there is nothing wrong with the door switch and/or lock.
#5 Posted : Tuesday, February 15, 2011 3:17:48 PM(UTC)
Originally Posted by: rainbonh Go to Quoted Post
Hi Gene
ser# 10119897EC. I found a heater,thermostat and a thermostat in the schematics but no cycling thermostat. They appear to be in the drum area or in back of the bottom panel. Thanks Tom
Tom,
The cycling thermostat is located on the blower housing cover and it is shown as #12 on the diagram.
- The cycling thermostat Part number: AP4053749
P.S. Have you ran the dryer after you cleaned the vent?
rainbonh
#6 Posted : Wednesday, February 16, 2011 5:20:06 AM(UTC)
rainbonh
This is really great. I will try it on the next drying day. If it does not work, Iwill order the part and report the findings. Thanks a million Tom
rainbonh
#7 Posted : Friday, February 18, 2011 10:01:49 AM(UTC)
rainbonh
I replaced the cycling thermometer, and we appear to be ok ,but I don't think it was the electronics of the thermometer. The thermometer had a big blob of lint on the sensing face, but I changed it anyway. Something to think about if you have the same problem. So although I ate a timer and maybe a thermometer I still came out ahead financially and I am much more knowledgeable because of all the help I got from all who got me there. Hope my experience will work out better for the next guy Thanks Tom
rainbonh
#8 Posted : Monday, March 7, 2011 5:58:06 AM(UTC)
rainbonh
Hi Gene
Tom
#9 Posted : Tuesday, March 8, 2011 8:10:07 PM(UTC)
Tom,
What is going on? The same problem came back or it is something different?
rainbonh
#10 Posted : Wednesday, March 9, 2011 4:37:24 AM(UTC)
rainbonh
Wife says dryer not drying clothes properly.Still works okayin timer mode,but has to run in thru twice cleaned the vent ,repaced the timer, replaced the
cycling thermostat,and ordered and replaced the thermostatpiece that the timer thermostat fits into. i'm going to open the vent in the basement below the dryer on the next wash day. how about the dial up top heat options?
Guest (7)
2 Pages12>
