I have a whirpool dryer that works fine but will not shut off at the end of a cycle,it just keeps going till i open the door or turn it to off,I replaced the timer but still the same.is there a relay or something I need to replace
no I have to push the start button
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) no I have to push the start button
Sorry for the delay.
Does it do it on both timed dry and auto dry?
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Sorry for the delay.
Gene. Yes it does it on all cycles
What is the part number of the timer you installed?
What is written on the timer motor and the label on the timer?
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) What is the part number of the timer you installed?
Gene. 8299778 model m460-g 1/3 hp,15/7.5a 076-0195a30864 ckt. tm-wb 0.25a 125/250vac 014-62717 ckt. tm-or bu-v 0.25a 125/250vac 8299778 FSP made in mexico I just took one wire at a time from the old to the new and plugged in.
Originally Posted by: bremark ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) 8299778 model m460-g 1/3 hp,15/7.5a 076-0195a30864 ckt. tm-wb 0.25a 125/250vac 014-62717 ckt. tm-or bu-v 0.25a 125/250vac 8299778 FSP made in mexico I just took one wire at a time from the old to the new and plugged in. nothing but timer does this
Originally Posted by: leosar ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) nothing but timer does this Everything works fine it just wont shut off,so we cant leave the house and let it finish a cycle.I also made sure duct was clear
