angelo c
#1 Posted : Monday, March 7, 2011 5:41:40 PM(UTC)
angelo c
Dishwasher won't fill and pump is loud
I have a Bosch mod. SHU3336 UC/14
I checked power to the control valve and starts out at no voltage and after about 20 sec. voltage goes to 120 volts.
I disconected the output side of the control valve and with 120 volts applied the water goes through the valve.
Any ideas....what do i look at next ??? :confused:
Thanks for any help you can give me.....Angelo
Applianceaid
#2 Posted : Tuesday, March 8, 2011 9:42:52 PM(UTC)
Applianceaid
Hello,
On the left side on top of the blue box unclip the harness to the little switch and reconnect it. I have seen this issue several times and by doing this it fixed the dishwasher.
On the switch ther are contatcs test them for the correct continuity.
ApplianceRepairLesson.com
