ppgopete
#1 Posted : Wednesday, March 2, 2011 12:31:41 PM(UTC)
ppgopete
I found this forum really helpful. So wen I hit a problem I thought I would check with this community as it has been most likely been solved before,
Yes the infamous -F3- problem is back.
My question is:
I noticed when looking for replacement keypad's "Key Panel" (item # 10" in GE database for this model), there are three distinct part numbers listed.
PS753840/41/42
In an earlier post I had seen a expert provide a PDF guidance on how to replace the key pad. There, there was a mention of two variants of the Keypad part. However, that was for a different microwave or a different model.
My question is does anyone have any idea how to determine the right part number, before I spend $80 on ordering the wrong one. I am hoping there is a number on the original when I pull it apart(fingers crossed)
Any help would be appreciated.
Joe / APP Team
#2 Posted : Thursday, March 3, 2011 11:59:36 AM(UTC)
Joe / APP Team
My question is:
PS753840/41/42
In most cases, consecutive part numbers designate a color :
(example ) ps753840 may be white and the 41 may be a black, etc.
Supply us with a complete model number and we'll be happy to advise you of the part needed.
ppgopete
#3 Posted : Thursday, March 3, 2011 12:10:19 PM(UTC)
ppgopete
Actual Microwave model is JVM1870SF03 spacemaker under the hood model
The keypad is black background with white text
Joe / APP Team
#4 Posted : Thursday, March 3, 2011 1:49:25 PM(UTC)
Joe / APP Team
Apparently we're using different parts screens ?
The part number needed per the GE parts diagram and the model number you supplied,
You need MPN no. WB07X10629
AppliancePartsPros part no.
Part number: AP3418746
ppgopete
#5 Posted : Friday, March 4, 2011 7:40:56 AM(UTC)
ppgopete
Aah! I see why the part numbers are different, you are referring to the entire assembly. I was referring to only the membrane key panel
retails aroun $70 while the assembly is closer to $150
Do you have a separate kepad or keypanel membrane available in ApplianceParts?
I am talking about item #10 in the attached parts diagram.
Thanks for all the help
ppgopete attached the following image(s):
Joe / APP Team
#6 Posted : Friday, March 4, 2011 9:12:38 AM(UTC)
Joe / APP Team
Sorry, But we don't have a part number for the touchpad panel as an individual part number, in any of our parts resource screens,
I have a feeling, if you order the pad assembly alone, it may substitute over to the complete assembly, (the part I listed) ?
Good Luck
