cardzfan
#1 Posted : Thursday, October 2, 2008 10:27:18 AM(UTC)
cardzfan
I've discovered a leak in our dishwasher. When I pulled the kick plate it appears that it is leaking around the sump pump. I'm guessing that I need to replace the sump pump gasket. Is that correct? If I'm on the right track, how do I go about replacing the gasket?
Any help would be appreciated.
Zanshin
#2 Posted : Thursday, October 2, 2008 5:44:08 PM(UTC)
Zanshin
Unless the unit has had limited operation and the gasket was allowed to dry out, you should be able to pull the motor pump assy , clean the sump seal and reinstall.
The easiest way would be to pull the entire unit out and lay it on the side, you are looking for 3 white pull out tabs, thats all that holds the pump in.
You will have to remove the drain pump in order to allow the motor/pump access.
