AppliancePartsPros.com
Appliance Repair Help
General Talk
Fridgidaire Gallery series Side-by-Side built 08/95
The model # is partialy worn off. I can only see FGS*****, can any tell what the rest of the numbers are? Fridgidaire Gallery Side-By-Side, Almond color, built in 08/95. I need the Ice Tray Assembly.:confused:
Rank: Administration
There are typically two places where a model number is listed on a fridge. One is on the inner side of the door and another is a small tag usually inside the fresh food or freezer compartment. The door tag has a partial model number while the other tag has complete model and serial numbers. Check both tags and let me know what you find.
I have a Frigidaire frigerator Gallery Side-by-Side, built in 08/95, Model #FRS26XGCD1. I need the Ice container or assembly. A plain ice container will. I just need something to hold the ice. Thanks Scott
Looks like the ice container for this model is no longer available. Frigidaire has discontinued making it. I can find one from a different model or brand, but it won't be the same size and I'm not sure if you'd be able to make it work. - Breakdown diagrams for Model FRS26XGCD1
General Talk
