Initially service man diagnosed as control board which I ordered and replaced. It now has power and lights which work but it will not start. Another service person diagnosed as control panel which I replaced but still will not start so it was not that. Where do I go next????
You should now check your thermal fuse. If it fails, your motor will not start. The Number on the part is 3390719..located on the blower housing. Remove the front lower panel to access ..wrench:)
I would advise you to sell it asis and no return no replace you better buy a usd one which will be cheaper than repair
