djt1963
#1 Posted : Thursday, February 24, 2011 8:16:18 AM(UTC)
djt1963
I have a Roper dryer by Whirlpool Coporation
Heavy Duty
Extra Large Capacity
6 cycle / 3 temperature
Model: RED4340SQ1
Serial #: MU4980113
Type: D433-RLE-2406026-FM54
About 5 days ago the timer quit working on my dryer. I would turn the dryer on & it just kept going - I found this out by waking up in the middle of the night & it was still going.
Yesterday it quit blowing warm air. You can tell air is blowing & it is oscillating just fine. It just cool air.
I am a single mom & can't afford a new dryer at this point.
I am fairly handy - any suggestions on repairing:confused:
djt1963
#2 Posted : Thursday, February 24, 2011 9:37:47 AM(UTC)
Replacement parts for WHIRLPOOL RED4340SQ1 29`` ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram
Before pulling the timer you may want to try the following.
Put the unit into an auto cycle, let it run and see if the timer advances.
I am guessing when it ran that night it was in an auto cycle.
Now put it in a timed dry cycle and let it run.
If the timer now advances then odds are your timer is OK.
In timed dry mode the timer motor get power directly from the lie through Timer Switch 0 contacts TM to WB.
In an auto mode it gets power through heating coil and Timer Switch 0 contacts TM to OR but only when the heating coil is off.
So if the heating coil blows (opens) the timer will not advance.
From your post I believe the unit still gave heat but would not shut off and now there is also no heat.
If this is the case it could be that the heater was grounded and it has now either blown or has blown the thermal cut-off (Item 6 in Section 3).
May also be that you have lost half the line.
If the timer advances in a timed dry mode your power is OK.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may has sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off..
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
File Attachment(s):
RED4340.pdf (506kb) downloaded 82 time(s).
tcio
#3 Posted : Thursday, August 21, 2014 11:31:44 AM(UTC)
tcio
Wow! I've watched endless Youtube videos on this subject yet never found this information. Thanks so much. I almost went and bought a new timer but I took it off "auto" mode and put it in "timed" mode and it then worked. So I'm guessing it's the coils although I already tested them with a multimeter and they seemed to test okay along with all the other components. I didn't test for exact ohms just continuity. Although the timer advances in "timed" mode the flame still goes out after about 1 minute and won't go back on.
