Molly 27
#1 Posted : Tuesday, February 22, 2011 3:45:19 PM(UTC)
Molly 27
The oven lights (both) still work. The clock and display still work. The range nor either oven works. When unplugged and plugged back in, the display says 3.0 flashes, then the 3.0 dissapears and only the time flashes. The element then worked for a second, and the on indicator went on. Maybe 2 seconds later went off, and nothing.?? Is it a fuse? and where are they to even check?
#2 Posted : Wednesday, February 23, 2011 6:47:54 AM(UTC)
A model number may help others help you
Dim Lights in controls of Maytag double oven range (Oven Repair (including Ranges and Cooktops))
by cityfolks 12/21/2008 4:11:30 PM(UTC)
