gonz6191
#1 Posted : Tuesday, February 22, 2011 8:26:33 AM(UTC)
gonz6191
My refrigerator stopped cooling so I called a repair guy and he opened the control panel inside the refrigerator portion and he determined that the relay on defrost control board was bad. So I bought a new one and it turns out that $100.00 later he was wrong because it's still doing the same thing. I called another repair guy and he was not able to pin point the problem. However, I have been able to keep it running by tapping the control panel everytime I notice that it's not running. There are only two parts inside the control panel: (A) The defrost control board that was changed and (B) A Thermostat. Do you think that it could be a bad thermostat?
The symptom is that the unit stops running and once I tap the control panel it immediately starts running. The fan and compressor will turn on...It just starts running like normal for a while and then an undetermined while later it will stop running again and on and on and on.
What is the typical symptom of a bad thermostat?
Please advise!
#2 Posted : Tuesday, February 22, 2011 12:11:20 PM(UTC)
Replacement parts for WHIRLPOOL GT2SHKXMS01 REFRIGERATOR | AppliancePartsPros.com
Sounds like a thermostat problem to me.
Just to confirm it the next time it happens just turn the temperature dial back and forth to see if it will start up.
You are trying to eliminate a loose connection as a possible cause which could give you the same symptoms and the tap is reconnecting it.
wrinkle249
#3 Posted : Thursday, May 12, 2011 8:51:44 AM(UTC)
wrinkle249
Was the thermostat the problem? I have EXACTLY the same symptoms, and the same fix... tapping once on the control panel. I removed the front of the panel and tap directly on the thermostat and it turns on... only to have it off everytime I get up in the morning.
If you can repost a YES it was the thermostat, or if it was something else, that would be great.
bdb808757
#4 Posted : Monday, December 12, 2011 11:06:56 AM(UTC)
bdb808757
Did anyone find out whether it was the thermostat or the control board? I tap the board and it cuts back on for an undertermined amount of time. Any help would be timely.
All the best,
-Brad
757-407-0041
ApplianceJunk
#5 Posted : Monday, December 12, 2011 11:12:24 AM(UTC)
ApplianceJunk
Hi Brad,
What is the model number of your refrigerator?
bdb808757
#6 Posted : Monday, December 12, 2011 11:28:21 AM(UTC)
bdb808757
Whirlpool ED5DHEXB
ApplianceJunk
#7 Posted : Monday, December 12, 2011 11:31:18 AM(UTC)
ApplianceJunk
Brad,
To test the defrost thermostat you would need to check it for continuity with a ohm meter. When the thermostat is in a cold freezer it should be closed or have continuity when checked with a ohm meter if it's good.
bdb808757
#8 Posted : Tuesday, December 13, 2011 6:02:59 PM(UTC)
bdb808757
I replaced the thermostat per the information mentioned by the individuals in this thread. The symptoms have subsided it seems. Additionally, I attempted to install a new control unit and ran into an issue when detaching the cable from what appears to be the larger connector of the 3 on the control unit. The issue is that this connector doesn't have lock/unlock mechanism to allow for detaching the connector from the board. Am I missing something, or does it not disconnect after it is installed? The board's part number is: AP4981837 ..-Brad
Brand New Refrigerator won't cool below 42 (Refrigerator & Freezer Repair)
by mariasamba 6/30/2018 1:48:34 PM(UTC)
Maytag refrigerator won't cool (Refrigerator & Freezer Repair)
by mimossi 4/25/2016 6:12:55 AM(UTC)
Frigidaire refrigerator won't cool (Refrigerator & Freezer Repair)
by pmandare 1/24/2015 9:08:02 PM(UTC)
Kenmore refrigerator won't cool. (Refrigerator & Freezer Repair)
by Tomjenks 12/4/2014 4:25:46 AM(UTC)
Refrigerator won't cool (Refrigerator & Freezer Repair)
by normskiboy 11/14/2011 1:01:31 PM(UTC)
GE Refrigerator won't cool (Refrigerator & Freezer Repair)
by DennyA 11/1/2011 9:42:23 PM(UTC)
kenmore side by side refrigerator won't cool (Refrigerator & Freezer Repair)
by possystems 9/5/2011 1:17:09 PM(UTC)
freezer is fine refrigerator won't cool (Refrigerator & Freezer Repair)
by KerryH2010 6/8/2010 7:03:56 AM(UTC)
Refrigerator won't cool more than 50 degrees (Refrigerator & Freezer Repair)
by greenbizman 12/15/2009 12:12:38 PM(UTC)
by postmaster2 8/26/2009 11:46:23 AM(UTC)
Haier 2.7 Refrigerator won't cool (Refrigerator & Freezer Repair)
by Walleye cooter 8/17/2009 12:20:46 PM(UTC)
Refrigerator won't cool down (Refrigerator & Freezer Repair)
by tech 6/2/2008 3:05:52 PM(UTC)
GE Refrigerator won't cool or freeze top half (Refrigerator & Freezer Repair)
by embalmer 12/28/2007 11:39:07 AM(UTC)
by millerbeachbum 11/16/2007 10:03:53 AM(UTC)
