6 Pages«<3456>
richappy
#41 Posted : Monday, February 21, 2011 5:31:45 PM(UTC)
richappy
If the motor is not turning the chopper, the motor impeller is bad, rather rare the check valve goes bad.
ljfreeze@optonline.net
#42 Posted : Monday, February 21, 2011 6:44:13 PM(UTC)
After looking at photographs posted on this site, it appears that my dishwaher is missing a foreign object protector. Is it possible that my model (GU2400xtps1) did not have one? If it is missing, could that cause the chooper to clog frequently?
richappy
#43 Posted : Tuesday, February 22, 2011 12:30:13 AM(UTC)
richappy
If the half round cover over the chopper is ok, this missing part will not affect the chopper as no, large objects will reach the chopper.
When you hand turn the chopper arm, there must be some smooth resistance showing it is coupled to the motor impeller.
mheather93
#44 Posted : Thursday, May 5, 2011 7:41:46 PM(UTC)
mheather93
Marc,
What is the complete model number of the dishwasher?
What exactly is wrong?
Have the same problem with my Whirlpool DU1145XTPB1 model. Top rack isn't cleaning well. Tried to get the hub off the lower sprayer arm - to no avail. Do I unscrew it or just pull it straight up? Don't want to break parts. After trying to unscrew for 5 minutes, lower wash arm is wobbly. Any help appreciated.
richappy
#45 Posted : Friday, May 6, 2011 1:29:36 AM(UTC)
richappy
There is a gray, plastic hub AP3039145 that the spray arm is screwed on, perhaps split, but just take pliers and twist off.
Rafy
#46 Posted : Wednesday, August 3, 2011 7:51:45 AM(UTC)
Rafy
Hi, I have this dishwasher and now the normal cycle light is bliking with a -- in the display. Is this a service code? Some one knows the meaning or were to download the service manual? Thanks.
#47 Posted : Wednesday, August 3, 2011 2:10:39 PM(UTC)
What is the end of the model number?
Rafy
#48 Posted : Wednesday, August 3, 2011 2:33:37 PM(UTC)
Rafy
The model number is gu2500xtps. Thanks.
#49 Posted : Wednesday, August 3, 2011 4:53:38 PM(UTC)
There is a one digit after "S". It is important to have it.
Rafy
#50 Posted : Wednesday, August 3, 2011 5:38:17 PM(UTC)
Rafy
Gu2500xtps6 Sorry about it.
Guest (14)
Whirlpool dishwasher WDT780SAEM1 (Dishwasher Repair)
by Guest 6/15/2023 1:10:41 PM(UTC)
Whirlpool Dishwasher Won't Advance Cycle (Dishwasher Repair)
by amappliancewi 3/28/2023 12:02:52 PM(UTC)
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool Dishwasher Wiring (Dishwasher Repair)
by Chitreano 6/21/2022 9:47:55 AM(UTC)
Whirlpool Dishwasher WDF520PADM7 Sanitized light blinking ***SOLVED (Dishwasher Repair)
by NC_OldGuy 5/20/2022 10:34:10 AM(UTC)
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Whirlpool Dishwasher: next steps to diagnose upper arms not spraying (Dishwasher Repair)
by erotenberg 1/9/2022 11:00:38 PM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
Whirlpool dishwasher drain issue (Dishwasher Repair)
by Bostomw 11/11/2021 3:54:47 PM(UTC)
Whirlpool dishwasher (WDF520PADM3) Cycle lights don't lit up (Dishwasher Repair)
by gowin09 6/13/2021 1:48:33 PM(UTC)
Whirlpool dishwasher door leak (Dishwasher Repair)
by Guest 5/26/2021 9:40:52 AM(UTC)
Whirlpool dishwasher - Replacing soap dispenser door? (Dishwasher Repair)
by NJGuy 5/17/2021 10:55:47 AM(UTC)
Whirlpool Dishwasher Intermittent Operation (Dishwasher Repair)
by Craigius757 3/12/2021 9:19:22 AM(UTC)
whirlpool Dishwasher WDT750SAHZ0 Leaking (Dishwasher Repair)
by Deanomich 10/15/2020 7:27:19 PM(UTC)
Whirlpool dishwasher shudders between wash/rinse and drain (Dishwasher Repair)
by aeb58DIY 7/6/2020 3:17:09 PM(UTC)
6 Pages«<3456>
