Originally Posted by: TMcTx ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I got the new switch in, everything works good, except the hot surface light is on all the time. The top is cool and all the switches are all off.
Any ideas.
Tim Tim I replaced my switch with APP part AP3775555 and the HOT SURFACE LIGHT went off after the burner cooled down. Did you ever fix this? See my comments later in the thread about the issue I had with the "N" connection wires. GSAM
I manage to take the pictures of the new switch not easy getting a clean shot. Notice the following Red and Pink wires are on the (L2B) connection TOGETHER BLACK & Grey Wire = (L1) YELLOW = (H1) ORANGE = (H2) BROWN Wires (2) of them = (P) Pin (L2) is NOT USED Pin between (L2) and (L1) no label, is not used Pin between (L2b) and (H1) no label, is not used This part was used to repair an FRIGIDAIRE FEC3026HSA / Electric Cooktop and may not represent the wiring for another cooktop. Good luck gsam attached the following image(s):
Originally Posted by: gsam ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I manage to take the pictures of the new switch not easy getting a clean shot. Notice the following
Good luck The exact same part was used to replace a Sears #903057-9010 part number, used your diagram and photos on a FRIGIDAIRE FEC30S6HBA. Great job, this is what the internet was invented for not all the other B.S. :D
Originally Posted by: MadlockMo ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The exact same part was used to replace a Sears #903057-9010 part number, used your diagram and photos on a FRIGIDAIRE FEC30S6HBA. Great job, this is what the internet was invented for not all the other B.S. :D I work in technology myself and a picture and diagram paints 1K words. Glad it could help. :)
Have read the thread, but I was wondering if replacing the switch will make the dual surface operate correctly. Right now no matter which way you turn on the burner (small numbers or large numbers), it always heats on the [COLOR="Red"]full area of the burner[/COLOR]...otherwise everything works fine. Or is there something wrong in the element?
What is the complete model number of the range?
