In replacing a defective dual infinite switch with a Maytag 12002125,the wire need to mapped and the schematic with the Maytax is insufficient to do this. My old switch has a red hot wire, two blue loads, a tan that seems to likely also be a load, and a yellow indicator light that, on the single infinite switches, doesn't seem to connect with any other wire on the switch whether the switch is on or off, so I don't know what that is doing.
The red and blue wires on the broken switch show no resistance, and the burner is not on continuously, so I seem to have an additional problem.
For model number AKT3650SS the part number for the dual infinate switch should be 12002422. Nat
