fhenness
#1 Posted : Tuesday, September 23, 2008 5:34:57 AM(UTC)
fhenness
water level not shutting off. before i replace pressure switch i want to know if small amount of water in the
plastic pressure cup at the bottom of tub has any
affect on level . low low works but the
thanks fran.
libertyappl
#2 Posted : Tuesday, September 23, 2008 11:36:37 AM(UTC)
libertyappl
If there is water in the tub you need to get that out. check for cracks or pin holes in the tube.
nat
fhenness
#3 Posted : Wednesday, September 24, 2008 4:58:04 AM(UTC)
fhenness
nat
water not in tub but small amount settles in the plastic air cup from which a plastic tube goes to pressure switch. i'll check hose for holes. would water in plastic air cup affect level in tub.
libertyappl
#4 Posted : Wednesday, September 24, 2008 7:15:16 AM(UTC)
libertyappl
If there is water in the tube(sorry didn't hit the E before) that will effect the water level.
Nat
richappy
#5 Posted : Thursday, September 25, 2008 1:45:57 AM(UTC)
richappy
I would blow in the end of that plastic tube to clear the water out. I also use a turkey baster and pump some vinegar down it to dissolve any soap residue.
