I would do one thing at a time. The vent has to be done first.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) You are welcome. Hopefully the problem is solved.
Gene. I suspect these are my problems as well. I have removed them, but how do I test them? TRMART
Originally Posted by: trmart ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I suspect these are my problems as well. I have removed them, but how do I test them? TRMART Can you be more specific on the problem please? The complete model number of the dryer would not hurt too. Gene.
Whirlpool Estate Model # TGDX640PQ0
Based on my novice troubleshooting, I suspect the problem is my gas coils. I have removed them, but don't know how to test them to see if they are functioning properly. Recommendations?
What exactly is wrong with the dryer?
Hi Gene, It works like brand new. The problem start out with the bad ignitor and replaced with a brand new defective one. Thanks
You are welcome. I'm glad you were able to find it.
Just wanted to say thank you for sharing your diagnosis and repair with us. It's not often we see an intermittent problem caused by a faulty igniter.
My problem is that the tumbler works but doesn't heat. Here is what I have diagnosed so far...
- Gas is on - Breakers are set - Fuse on back of dryer work - Ignitor box glows red for 10-15 seconds then stops
I have removed the gas valve coils, as they may be a likely suspect, but I don't know how to test them to determine if they are the problem. Ideally, I would prefer not to get the replacement coils, install them, then determine that they weren't the problem.
