shorner
#1 Posted : Monday, February 14, 2011 11:14:05 AM(UTC)
shorner
The display on the control panel showing the time, power setting, etc. is very dim and difficult to read. The switch works fine, it's just very dim. Should I order a new board?
Thank you!
Jeff / APP Team
#2 Posted : Monday, February 14, 2011 12:28:33 PM(UTC)
Jeff / APP Team
Yes you are correct. If the display is dim then you will need to replace the control board. The correct part number is Part number: AP4262913
. Hope this helps!
shorner
#3 Posted : Monday, February 14, 2011 1:10:20 PM(UTC)
shorner
Originally Posted by: Jeff / APP Team Go to Quoted Post
Yes you are correct. If the display is dim then you will need to replace the control board. The correct part number is AP4262913. Hope this helps!
Thank you!
